mk 4 and mk 5 r gearbox same
Postby stevejoe » Thu Dec 31, 2009 12:36 am
r mk 4 gearboxes same as the mt75 mk 5s
stevejoe
Re: mk 4 and mk 5 r gearbox same
Postby Luke » Thu Dec 31, 2009 12:38 am
sort of :| ......... which ones exactly :?:
Postby psv-hgv-flt » Thu Dec 31, 2009 12:40 am
late mk4 is, late 1988 f,reg on. :wink:
psv-hgv-flt
Postby stevejoe » Thu Dec 31, 2009 12:45 am
was just looking at a gearbox 2 day that was out ov my old mk4 think it was a l L reg and it looked relay small 4 sum reason
stevejoe
Postby psv-hgv-flt » Thu Dec 31, 2009 12:52 am
stevejoe wrote:was just looking at a gearbox 2 day that was out ov my old mk4 think it was a l L reg and it looked relay small 4 sum reason
might be for a petrol as the bell-housing was smaller.
psv-hgv-flt
Postby Luke » Thu Dec 31, 2009 12:54 am
what engine are you after it for :?: petrol boxes are different between mk4/5 diesel are the same but mk4 uses the diesel box for petrol engines :)
Postby stevejoe » Thu Dec 31, 2009 12:58 am
no was not petrol was oil burner when i say small i mean not very long the gear stik bit is very close 2 the main bellhouseing bit
stevejoe
Postby Luke » Thu Dec 31, 2009 1:02 am
sure it was a mk4 not a mk3 :?:
Postby psv-hgv-flt » Thu Dec 31, 2009 1:03 am
stevejoe wrote:no was not petrol was oil burner when i say small i mean not very long the gear stik bit is very close 2 the main bellhouseing bit
mt75 is an all alloy box with stick in middle, cast type 9 box stick is two one side.
psv-hgv-flt
Postby stevejoe » Thu Dec 31, 2009 1:05 am
def mk4 it was a old lwb parsal van with the pre banna engine
stevejoe
Postby Luke » Thu Dec 31, 2009 1:06 am
should be same then :? :)
Postby stevejoe » Thu Dec 31, 2009 1:11 am
just remembered i got that van with no engine and box from bluecycle i got engine box from a breaker
stevejoe
