Van doesn't like going up inclines! Old or expected?
Postby thehangmen » Thu May 11, 2006 8:45 pm
LWB Mini-bus with a 2.5D (no turbo), 1994 approx 1380000 miles - if it has to slow on an uphill stretch or the stretch is too long in some cases we have to drop a gear or two to get it up there! Got artics passing us sometimes!
Is this normal-ish and nothing to get too cocerned about or is it the first signs of the engine going out to graze?
thehangmen
Postby FredTransit » Thu May 11, 2006 8:46 pm
How many people and how much gear did you have in the back?
FredTransit
Mk2 Trannyist
Postby thehangmen » Thu May 11, 2006 9:14 pm
FredTransit wrote:How many people and how much gear did you have in the back?
It's usually 4-6 people and the gear is a couple of amps and a drumkit, plus some luggage at the most.
When there's just a couple of people it is slightly better but not brilliant.
thehangmen
Postby FredTransit » Thu May 11, 2006 9:18 pm
Sounds like a fully loaded Mk2 luton! It would be normal for me, but it does sound a bit slow for a minibus.
FredTransit
Mk2 Trannyist
Postby Transitwalla » Thu May 11, 2006 9:21 pm
thehangmen wrote; approx 1380000 miles
A million and a quarter miles plus and still going :lol: and you've got the nerve to complain about a tired engine :lol: :lol: :lol:
Seriously . . time to check all the consumables.....fuel filter, timing belt, fan belt and oil filter then the valve clearances, dragging brakes etc etc anything you can think of that can / will slow the van down.
Start with the easiest things first . . .then condemn it to death :lol:
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Re: Van doesn't like going up inclines! Old or expected?
Postby Luke » Thu May 11, 2006 9:25 pm
normally i'd say just a normal slow transit but
thehangmen wrote:Got artics passing us sometimes!
that sounds a bit too slow :?
when it has a full tank of diesel is the performance any better than with 1/4 tank :?:
Postby thehangmen » Thu May 11, 2006 9:39 pm
Luke wrote:normally i'd say just a normal slow transit but
I'd say yes, but haven't really monitored it to any great extent.
thehangmen
Postby Luke » Thu May 11, 2006 9:45 pm
thehangmen wrote:I'd say yes, but haven't really monitored it to any great extent.
that could (but not necessarly) be a problem with the diesel pump :? - but like teamster says check the fuel filter etc. 1st! pump would be last resort!!! :)
Postby thequadsquad » Thu May 11, 2006 10:13 pm
thehangmen wrote:LWB Mini-bus with a 2.5D (no turbo), 1994 approx 1380000 miles - if it has to slow on an uphill stretch or the stretch is too long in some cases we have to drop a gear or two to get it up there! Got artics passing us sometimes!
Your problem sounds exactly the same as mine, i've just had a recon engine, and even the slightest incline, i was having to drop down, pain to start first thing,gutless on straights, took van back to scrappy, and all he's done is adjust mixture screw, don't know if it will help your problem, but my van now pulls like a train on inclines, and flies on straights, hope this might help :D :D
PLAY UP POMPEY, POMPEY STAYED UP
thequadsquad
Postby 100ps_drw_hicube » Thu May 11, 2006 10:24 pm
just one more thing :lol: being a minibus it might have a 4.63 diff that wont help at all on big hills :( i have noticed a lot of minbusses come flying past me on the flat only for me to fly past them on the slightest of inclines :? :lol:
100ps_drw_hicube
Transit Abuser!!
Thannx!
Postby thehangmen » Fri May 12, 2006 4:31 pm
Thanks - so going to check out the fuel filter then the screw adjustment and keep the fingers crossed.
thehangmen
Postby Transitwalla » Fri May 12, 2006 9:37 pm
Whats the chassis number?
Jim.
Transitwalla
Postby motorwise » Fri May 12, 2006 9:43 pm
Teamster wrote:Whats the chassis number?
stand near a hill and you'll probably be able to write it down as he passes - sorry - :wink: - sometimes they are a bit sluggish up hills - check the cam and pump timing and give it a good service - can't do any harm
http://www.motorwise.net
motorwise
Postby Transitwalla » Fri May 12, 2006 9:46 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: 8)
Jim.
Transitwalla
Postby Transitwalla » Fri May 12, 2006 9:48 pm
Ok . . realise its not the best idea to post a chassis number on any forum . . . if you like, PM, me and we'll go from there.
Jim.
Transitwalla
