tourneo 2003 rear door cracks
Postby mrtaximan » Fri Apr 29, 2005 1:49 pm
hi all back again this time with cracks on the one piece rear door.on both sides about 9 inches up from the bottom of the door behind the interior light switches a crack has appeared.It also extends about 2 inches above and below the switch on both sides.before i go to the local ford dealer again ( he loves me) and demand he puts it right under warrenty has anybody heard about this problem before.Mark.
mrtaximan
Postby FredTransit » Fri Apr 29, 2005 2:52 pm
The Mk2s used to do this, but not at two years old. I am shocked and stunned. :shock: I was always lead to believe from the Mk2s that this was down to maintenence, and how the door was used. We are planning a one piece (or rather a horizontal two piece) on our stretch, and looked at a hell of a lot of scrappers with this type of door before we found one without tiny cracks. I have always taken this as being a design fault too, when you think about it you are taking a big heavy piece of metal (lower door) and pivoting it on a little piece of metal (window frame) Is this ever gonna stop? What do Ford think they are playing at? You would expect a bit more of life from something that cost you 1000s....................
FredTransit
Mk2 Trannyist
Postby madmark » Fri Apr 29, 2005 8:29 pm
mark i havent herd of this before yet anyway! :?
cracked rear doors ?
Postby trannytech » Fri Apr 29, 2005 11:04 pm
havent heard of this either
trannytech
tourneo door cracks
Postby mrtaximan » Mon May 02, 2005 2:53 pm
hi all, i am going to take the car to the local ford dealers and create f***ing hell.This not what you expect from a two year old commercial built for use as a taxi and is now falling to bits at only 72,000mls.this not what you pay top money for.
wish me luck and will report back soon.mark.
mrtaximan
Postby FredTransit » Mon May 02, 2005 2:57 pm
Best of luck MrTM, give em hell! I know I would. If no joy, go to the CAB or Trading Standards, there is such a thing as 'Merchantable Quality, which means an item has to be of suitable quality for the job it's made for. Sale of goods act, 1981 I think (could be wrong about the year, check with trading standards)
FredTransit
Mk2 Trannyist
Postby Valsheda » Tue May 03, 2005 10:43 pm
WOW MATE , YOUR NOT HAVING MUCH LUCK WITH YOUR VAN MATE ,
AND WITH THE BIG BUCKS YOU WOULD OF PAID FOR YER VAN YOU SHOULDNT BE HAVING THESE SORT OF PROBLEMS , I THINK YOU SHOULD BE GOING STRAIGHT TO THE TOP BOD OF YOUR DEALERSHIP GRABBING THEM BY THE SHORT AND CURLIES AND SAYING , TAKE THIS VAN BACK AND GIVE ME ANOTHER ONE NOWWWW :twisted:
Valsheda
Top Tourneo Owner
door crack update.
Postby mrtaximan » Wed May 04, 2005 2:18 pm
hello all,will be going to fords on monday to get this door prob sorted if not i may demand some sort of compo for loss of earnings etc.We shall see!!! mark.
mrtaximan
Fords V Mercs
Postby baconsdozen » Wed May 04, 2005 5:31 pm
Hello All.My other van is an old Merc 307D.A few years back the exhaust down pipe split and I couldn't get one anywhere.In those days I used the van everyday and driving it sounding like a dragster was a bit worrying in terms of attracting the Old Bill.More as a joke than anything I faxed Mercedes in Germany pointing out that my van was only just over 20 years old and had done only about 350,000 miles.I told them I'd already had to adjust the brakes a few times,pump the tyres up and change the oil and now the exhaust had split.Two days later a pipe was delivered to the local dealer via Norwich airport along with an note from Mercedes saying that as a good will gesture they had waived any charge.I've not tried the same thing again when other bits have fell off or worn out and the van (like me) has now seen better days but I still use it every so often.I'm sure that because I've repeated this story to others over the years Mercedes have gained something out of it,you could always bore your Ford dealer silly with this little tale,maybe Ford themselves might be interested in copying a little bit of German customer relations.Vorsprung durch technik and all that.
baconsdozen
Postby FredTransit » Wed May 04, 2005 6:45 pm
A free exaust form Mercedes! That's helarious!! I bet you it wouldn't work with Ford's though, too tight..........................
FredTransit
Mk2 Trannyist
Postby trannytech » Wed May 04, 2005 10:32 pm
you'll be lucky!!!!!! probably put you on to ford customer services they once said to a customer "we didnt ask you to buy a transit"
trannytech
Postby trannytech » Wed May 04, 2005 10:33 pm
he was understandably pi55ed off
trannytech
Postby FredTransit » Wed May 04, 2005 10:36 pm
trannytech wrote:you'll be lucky!!!!!! probably put you on to ford customer services they once said to a customer "we didnt ask you to buy a transit"
Er well, actually I would say the adverts did, if not in so many words! :lol:
FredTransit
Mk2 Trannyist
Postby trannytech » Wed May 04, 2005 10:38 pm
true but they couldnt care less once youve brought one
trannytech
Postby trannytech » Wed May 04, 2005 10:40 pm
new trannys arent as good as the older ones to flimsy and over complicated
trannytech
