ford transit gear box problem
Postby brianset » Sun Jan 03, 2010 8:52 pm
hi i have a 03 transit 2ltr durotec fwd swb, my problem is it wont select any gears the gearstick just moves freely. i lifted the bonnet and by moving the selector at the gearbox i managed to find a gear and got it home. question does this sound like the gear linkage cable has snapped? have had no problem with it till today and it just went without warning. if so how easy/hard is it to change if this is the problem??
brianset
Re: ford transit gear box problem
Postby locost1 » Sun Jan 03, 2010 9:04 pm
its quite easy. At least the problem is between the stick and the box and not in it!
http://www.tjtransport.co.uk
1989 Mk3 luton 2.5. now it runs!!
locost1
Postby MrMPuk » Sun Jan 03, 2010 9:06 pm
Might be that one of the cables has come off.
Postby brianset » Sun Jan 03, 2010 9:20 pm
the gear stick i forgot to mention just moves backwards and forwards and doesnt seem to select a gear at all, would this account for a cable snapped?
brianset
Postby MrMPuk » Sun Jan 03, 2010 9:25 pm
No you did mention it, that's why I said maybe one of the cables has come off.
Postby brianset » Sun Jan 03, 2010 10:43 pm
MrMPuk wrote:No you did mention it, that's why I said maybe one of the cables has come off.
many thanks
brianset
Postby winterheating » Sun Jan 03, 2010 10:47 pm
if you can move it foward and back but not side to side it could also be the selector thats seized.
very cheap to repair do a search theres loads on it.
winterheating
