PAS tensioner
PAS tensioner
Postby Aly Johnson » Sun Jan 03, 2010 10:52 pm
Hi Guys,
Ive recently bought a 2LT diesel 53 plate swb transit which untill when i started it this morning runs very well.
When i did start it a noticed a squeek and a burny smell, so when i had a look under the bonnet the PAS/Water pump belt was burning against a siezed tensioner pulley!!
My questions are, is this common as it happened overnight, it was running perfectly the night before??
Is this job a bugger to do, ie anything that is prone to breaking while i dismantle the damaged parts??
And where should i buy the parts from and what would i expect to pay (are non genuine parts as good)
I have got some mehanical skills and common sence lol, so is this a job for DIY??
Thanks for all your help in advance, Aly Johnson.
08 plate MWB 350 2.4 LX
Aly Johnson
Re: PAS tensioner
Postby gemma08 » Mon Jan 04, 2010 2:40 pm
Just been there.Nothing too difficult you can easily fit new bearings to tensioner pulleys.but if you need a new belt or other bits Ford is the way to go.
may the fleas of a thousand camels infest your armpits
gemma08
