need help opening the bonnet on a 02 ford transit key wont w
Postby davef33 » Tue Jan 05, 2010 10:56 pm
need help opening the bonnet on a 02 ford transit key wont work
davef33
Re: need help opening the bonnet on a 02 ford transit key wont w
Postby MrMPuk » Tue Jan 05, 2010 11:03 pm
Make sure the grille is fitted correctly maybe even try it with the grille removed.
Postby GBBiker » Tue Jan 05, 2010 11:10 pm
davef33 wrote:need help opening the bonnet on a 02 ford transit key wont work
First, is it your van?
GBBiker
Wrong Again!
Postby davef33 » Tue Jan 05, 2010 11:22 pm
yeah its my van.tried everything to get the bonnet open had it open this afternoon.went to jump start it tonite and the key wont open the bonnet for me.id like to open it with as little damage as possible.is there a cable or something i can try and pull.i already have the grill off. thanks guys
davef33
Postby stevo » Tue Jan 05, 2010 11:27 pm
I had this problem mate, also with opening the fuel filler cap. Ended up being the key, got a new one cut and job done.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby knighty1981 » Wed Jan 06, 2010 2:55 am
davef33 wrote:yeah its my van.tried everything to get the bonnet open had it open this afternoon.went to jump start it tonite and the key wont open the bonnet for me.id like to open it with as little damage as possible.is there a cable or something i can try and pull.i already have the grill off. thanks guys
I've got one thats exactly the same....
I get it to work by pushing the key in hard, and keep it in hard, turn it to the left first (so it pops open a bit) and then turn it to the right (holding it in hard the entire time)...then lift the bonnet while holding the key there...
works for me every time like that.... and I showed someone else the same thing when his was stuck and it worked for him !
I thought they were all like that until i got another van and you didn't have to do it like that :o
knighty1981
Postby ake » Wed Jan 06, 2010 7:18 am
Is the lock frozen :?: If you cant get it open the battery is under the seat, you could connect jump leads to it :wink:
