Best way to change the injectors on a 2.5 (bannarna) engine
Postby tomos44 » Sat Jan 09, 2010 5:06 pm
should the engine be hot or cold, do i need an injector lifter?
tomos44
Re: Best way to change the injectors on a 2.5 (bannarna) engine
Postby psv-hgv-flt » Sat Jan 09, 2010 5:16 pm
tomos44 wrote:should the engine be hot or cold, do i need an injector lifter?
hot, injector lifter only if you need or have probs. :wink:
psv-hgv-flt
Postby bazw » Sat Jan 09, 2010 5:49 pm
hot sure helps in this weather , keeps ya hands warm :mrgreen:
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby jay » Sat Jan 09, 2010 7:46 pm
run engine hot..Remove the inlet manifold and slacken the bolts that hold the injector in place (only 1 or 2 turns)run the engine and all 4 injectors will hopefully either smoke round the sides of them or bounce up and down a little..The engine may misfire as well(this makes the injectors loose making it easier to remove them)..stop engine once all 4 are moveable remove all injectors and refit new ones but dont forget new sealing rings..oh and torque the injector bolts up when done..
mk1 connect tourneo
jay
