light fault
light fault
Postby the gurns » Sun May 14, 2006 7:03 am
Hi,has anyone had this problem before,every now and then when I put the sidelights on on my '96 smiley face the buzzer comes on and main beam light comes on permenantly??? if I then switch to main beam only one headlight comes on,it doesn't happen all the time so i suspect that water is getting somewhere it shouldn't be..any idea's???? :cry:
the gurns
Postby Transitwalla » Sun May 14, 2006 10:37 am
Firstly make sure all your grounds are good . . .no good checking for anything in the loom unless the grounds to the body are good. Then work systematically through the multiplugs making sure that they are connected and dry. You dont say how old the van is . . I have had corroded wires on a multiplug where water ingress was a problem . .to the naked eye the wires looked OK :) only to find that one or two came out of the multiplug when pulled slightly :( .
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Re: light fault
Postby rover » Sun May 14, 2006 11:15 am
the gurns wrote:Hi,has anyone had this problem before,every now and then when I put the sidelights on on my '96 smiley face the buzzer comes on and main beam light comes on permenantly??? if I then switch to main beam only one headlight comes on,it doesn't happen all the time so i suspect that water is getting somewhere it shouldn't be..any idea's???? :cry:
Rover.
rover
Postby MWOOLY10 » Sun May 14, 2006 12:49 pm
I have the same problem with my transit..All i do is wiggle the wires on the back of the headlamp and it goes ok,til the next time :)
Cheers Mike
MWOOLY10
Postby stevo » Sun May 14, 2006 6:20 pm
That sounds like a bad contact somewhere.
stevo
