tire pressure on untreated back roads
Postby ihaveagsxr » Mon Jan 11, 2010 10:53 am
when your on roads that are basicly snow and ice, is it better to drop pressures or leave them the same?
ihaveagsxr
Re: tire pressure on untreated back roads
Postby angeleye » Mon Jan 11, 2010 11:54 am
lowering pressures can work,but its not worth it, i would imagine you would need them below 30psi. only for fresh snow.. 30psi is no good for normal running.running on ice is the same as running on tarmac.tyres would f*** up in no time.bar running studded tyres its high gears and gentle smooth driving.
angeleye
