ECU
ECU
Postby Maltesefalcon » Mon Jan 11, 2010 1:08 pm
Hi All,
I have a 2000cc EFI 8v engine . I know that this engine is also fitted in scorpio and galaxy models. Can anyone tell me what is the difference in the ECU as they have different part numbers?
Maltesefalcon
Re: ECU
Postby Altransit » Mon Jan 11, 2010 5:33 pm
That twin cam engine was used in the late Sierras and Granadas and Scorpios :wink: I'm fairly sure that the Galaxy has a different engine.
Different ECU's would have been used for such things as autoboxes, air con, etc. as well as the vehicle itself needing different engine power.
Re: ECU
Postby GBBiker » Mon Jan 11, 2010 5:45 pm
I always thought the Galaxy was a 16 valver or 24 valver :?
GBBiker
Wrong Again!
Re: ECU
Postby madmart132 » Tue Jan 12, 2010 1:29 am
The early 2.0 galaxy was fitted with the vw golf gti engine !! The later versions had the 16v 2.3 ltr engine best to look on ebay uk for the ecu they are quite common in the UK hope this helps
madmart132
Re: ECU
Postby GBBiker » Tue Jan 12, 2010 1:34 am
madmart132 wrote:The early 2.0 galaxy was fitted with the vw golf gti engine
Yeah, MK4 Golf. 16 Valves like I said.
GBBiker
Wrong Again!
Re: ECU
Postby AndyG » Tue Jan 12, 2010 1:49 am
Re: ECU
Postby GBBiker » Tue Jan 12, 2010 1:53 am
Andyg wrote:http://en.wikipedia.org/wiki/Ford_I4_DOHC_engine
You believe everything Wiki tells you Andy? :shock:
GBBiker
Wrong Again!
Re: ECU
Postby AndyG » Tue Jan 12, 2010 2:06 am
No, but it is a fact that the early Galaxy did actually use the 8v engine, as it's been mentioned on here when people are looking for a second hand engine for their petrol MK5 Transit :D
Re: ECU
Postby Maltesefalcon » Tue Jan 12, 2010 10:10 am
So if I swap the ECU by a scorpio or sierra do I increase power ?
Maltesefalcon
