MOT emissions failure
Postby v8turbo » Thu Jan 14, 2010 12:48 am
Hi Guys,
My Transit failed its MOT on emissions! Just brought it over a week ago as a project, Its running a 2.0 pinto and has a newish weber 32 34 DMTL 0 135 06 carb, the MOT tester tried to adjust the mixture as far as it would go but it was still way out! I have searched the net for info on the carb and nothing shows up with that number stamped on the carb?
330 SWB rwd mk6 petrol waiting to fit Jaguar XJR V8 Supercharged engine!
v8turbo
Re: MOT emissions failure
Postby AndyG » Thu Jan 14, 2010 1:00 am
What exactly did it fail on :?: (hydrocarbons, Co :?: )
And by how much :?:
Postby v8turbo » Thu Jan 14, 2010 1:13 am
It failed on both, CO needed to be down under 3.5 and mine is over 7.1, hydrocarbons was way high but I dont remember what! not sure if the carbs right for my engine? MOT tested turned the idle mixture as far in as it would go but could not get it to read lower? I have brought a Gunsons gastester so will have a fiddle :?
v8turbo
Postby AndyG » Thu Jan 14, 2010 1:18 am
Is the air filter clean/good :?:
Check the colour of your spark plugs after a run :idea:
Also check that they're all firing too :!:
Postby v8turbo » Thu Jan 14, 2010 10:28 am
air filter is good, plugs are black and sooty due to running rich, I can not take it for a good run as it has no mot.
v8turbo
Postby AndyG » Thu Jan 14, 2010 2:54 pm
Well it does sound like either it's the wrong carb, the jets aren't correct for the application (your engine) or there's also a slight possibility that the float chamber isn't working correctly, allowing the excess fuel to just pour into the engine :idea:
I'll see if madmark has any ideas on this :D
Postby v8turbo » Thu Jan 14, 2010 4:45 pm
took the carb off checked it all and refitted it, brought a gunsons gastester and been messing about with the idle mixture, if I wind the mixture screw in too much engine stalls, so I have turned it out as little as possible to get it to run on tickover at the leanest setting. The gastester as to be set at 2.0 and left for 10 mins, when put in the tail pipe this setting drops to 1.5 to 1.7? the gunsons manual is very sparse on infomation! any one used a gastester? looking on the floor it has a large black sooty deposit patch under the tailpipe :twisted: did a search on the net and have read to put acetone in the fuel tank? or use some injector cleaner?
v8turbo
Postby mr. pitts » Thu Jan 14, 2010 5:24 pm
V8,
it's not the choke system sticking in the on position by any chance?
mr. pitts
Postby mr. pitts » Thu Jan 14, 2010 5:30 pm
v8turbo wrote:air filter is good, plugs are black and sooty due to running rich, I can not take it for a good run as it has no mot.
Black sooty plugs can also be a symptom of an ignition fault. Put a new plug in one of the leads & check what the spark is like.
On a more personal note, if you have any electrical parts made by Intermotor, throw them away, i can almost guarantee they are duff, even if new. :roll:
mr. pitts
Postby v8turbo » Thu Jan 14, 2010 5:48 pm
mr. pitts wrote:V8,
no checked that, have taken off the air filter and been running it off to check choke
v8turbo
Postby v8turbo » Thu Jan 14, 2010 5:50 pm
cap and plugs look newish, and leads look ok, this setup has an ECU to run the dizzy....
v8turbo
Postby Altransit » Thu Jan 14, 2010 7:43 pm
It's been a long time since I messed around with a carburettor, but from what I remember, with a Weber, adjusting the idle screw, does nothing for the running mixture, as that is handled by a different set of jets entirely :wink:
Postby hornhead » Thu Jan 14, 2010 8:08 pm
Hi would say new plugs and oil then carb.
if you turn in mixture till its hunting then speed up idle,CO goes down.
mot tester showed mewhen i took weber in for first time...i like really relaxed tick over but you can't get low co that way..thats why vv carbed ones idle so fast,to not misfire.
now have 2 paint marks on screws,mot setting and how it should be :D
hornhead
Postby AndyG » Thu Jan 14, 2010 9:06 pm
v8turbo wrote: if I wind the mixture screw in too much engine stalls, so I have turned it out as little as possible to get it to run on tickover at the leanest setting. The gastester as to be set at 2.0 and left for 10 mins, when put in the tail pipe this setting drops to 1.5 to 1.7?
Is that not OK for the MOT :?:
And as already mentioned, turn the idle up slightly too :idea:
Postby v8turbo » Thu Jan 14, 2010 10:21 pm
Altransit wrote:It's been a long time since I messed around with a carburettor, but from what I remember, with a Weber, adjusting the idle screw, does nothing for the running mixture, as that is handled by a different set of jets entirely :wink:
yes the idle mixture screw adjusts the CO (these sometimes are hidden with caps), and the fast idle screw adjusts tickover
v8turbo
