Inertia switch found!
Postby dirty dee » Sat Jan 16, 2010 2:24 pm
Having decided that my van may not have been fitted with an inertia switch after a long time of searching, phone calls and emails, I have spent ages trying to find a wiring problem. My local Ford garage had told me that there was likely to be a wiring problem as there is no inertia switch fitted to my van. After a long time of trying to find a wiring problem, I found the inertia switch NOT where it is said to be. Supposed to be above the NS front arch, however after finding a sticker indicating the fuel cut off above the OS front arch when you open the door, I finaly found it!
I see this sticker everytime I get in the van! Talk about being right under your nose! :oops:
dirty dee
Re: Inertia switch found!
Postby Frag » Sat Jan 16, 2010 3:41 pm
Who said it was on nsf arch ?
Askin on here would have saved you all that headscratching. :)
EDIT,checked your other posts & you did ask !
Never saw the question i`m afraid :(
Frag
Ford Technician
Postby transitrecovery » Wed Jan 20, 2010 12:16 am
whats the inertia switch do as i have one, is it for the second battery? if so when i turn it off the van just clicks so is that battery dead? when i turn it back on it starts fine?
transitrecovery
Postby MrMPuk » Wed Jan 20, 2010 12:18 am
The one above is talking about the switch to reset the fuel cut off after an accident.
Postby transitrecovery » Wed Jan 20, 2010 12:21 am
oh i see lol ok i will keep quiet lol
transitrecovery
