Slow 190
Slow 190
Postby 2Smoke » Tue May 16, 2006 3:57 pm
Ok, I'm sure this has been done to death but my new van is horrendously slow and heavy on fuel. Its a 190 on a P plate 25.di with the bosch pump.
I have done the pump tweak and egr mod and its still pretty slow, struggles to top 70 and takes and age to get to 60.
There is no major slack in the throttle cable.
It also seems a lot worse on fuel than my old 120 pre-di but this could be connected to the fact that you have to keep the throttle pinned everywhere.
After doing the tweak and egr mod it went better, but still not as good as I would like it to be.
Its also a bugger to start in the mornings, got new fuel and air filters.
Any ideas anyone? I have read through a few related posts to no avail!
Thanks!
Paul
2Smoke
Postby 100ps_drw_hicube » Tue May 16, 2006 4:28 pm
are the brakes dragging?? :lol: :lol: nice easy one to check :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby 2Smoke » Tue May 16, 2006 5:44 pm
You know, that is one thing I didnt check.. I'll have a look now!
Thanks!
Paul
2Smoke
Postby 2Smoke » Tue May 16, 2006 6:43 pm
Hmm brakes are fine.. although the previous owner mentioned something about this part of the pump.. doesnt look right to me!
2Smoke
Postby jay » Tue May 16, 2006 10:06 pm
top arrow should have a threaded bit which gets pushed by the bottom arrow bit when the engine is cold to give it a bit more throttle when at idle when cold..dont make any diffrence to the normal running at all..u may just find the van is a bit slow at idle when cold..
mk1 connect tourneo
jay
Postby Aztran » Wed May 17, 2006 10:33 am
Mines the same......tops at 65mph and screams out for help after that...
i put it down to the weight in the back
2000 x, new style Transit 350!
Aztran
Postby tractive-effort » Thu May 18, 2006 11:52 am
Have a look at this thread - I had a similar problem with mine a few weeks back and I'd bet it will be similar with yours mate!?! The mod has to be done by a diesel injection specialist though. Hope it helps anyway!! :)
http://www.fordtransit.org/forum/viewtopic.php?t=5411
tractive-effort
Postby 2Smoke » Wed May 24, 2006 1:14 pm
tractive-effort wrote:Have a look at this thread - I had a similar problem with mine a few weeks back and I'd bet it will be similar with yours mate!?! The mod has to be done by a diesel injection specialist though. Hope it helps anyway!! :)
Thanks, so is it a lot better now? Any idea what the problem was?
Cheers!
Paul
2Smoke
