Hi, I am going to have a go at changing the water pump on my 2001 transit swb front wheel drive.
The van just keeps cutting out, temp gauge races up to H, then engine light comes on, then van stops.
If I remove the cap of the water the van runs fine.
When the cap is on the heaters get hot for aout 1 min then get cooler and cooler.
The top pipe gets hot but the bottom one does not.
I am guessing its the pump?
If it is what is it like to change, does the timing belt need to be removed and how easy is it, any diagrams to help me?
