The above pics are of two u shapeed brackets inthe middle of the leaf spring.
They are both loose, and the other side is solid!
Should these be tightened?
ive noticed a noise when i go up curbs and i reckon this is it?
yesAndyg wrote:Can Aztran not flood the studs with penetrating oil first then try and do them up
Luke wrote:had yours come looseAndyg wrote:Should I be fitting new ones on as well
