viewtopic.php?f=2&t=59236
and driving 130miles on three pots my Di turbo 85ps has now got a rocky tick over. It's fine other then that. As soon as the throttle is pressed it all goes smooth & there is no loss of power. I have slackened the injector unions one by one and proved the problem is on No 2 cylinder again. Also i've swopped no 2 & 3 injector to eliminate those. I've also changed the fuel filter, filling the new one up with injector cleaner to try to help things along. When the motor is cold it ticks over not bad but as it gets up to tempreture it gets worse. Question is have i knacked the pump
If i have damaged it, what damage has it done & why?
