carb help please
carb help please
Postby Wolfie » Fri May 19, 2006 6:46 pm
my v4 2l carb looks like it kaput, something to do with the vent bit being worn or something like, what weber will fit straight on please????
1979 2L pinto camper
Wolfie
Postby madmark » Fri May 19, 2006 6:52 pm
34 ich i think its called ,or zenith 36 1v you will have to be carefull with yours as you probly will have the bolt throu the airfilter pan ,after 75ish they didnt do this anymore ,so basicly what i mean is getting a erly carb is going to be harder than a later carb,if you were to get the weber replacement there isnt much way of holding on the airfilter pan! :(
Postby Wolfie » Fri May 19, 2006 7:02 pm
yes the air filter is the bolt through jobbie to the top of the carb.
cheers better start looking in the scrappies then.
Wolfie
