high pitched noise under bonnet
Postby staites » Thu Jan 28, 2010 3:33 pm
Hi everyone, i have looked at van today first one, never bought one before, the van has a high pitched sqeeling sound
from under bonnet can anyone advise as too what it could be, The van is a 2001 y reg Transit van, 2402 diesel engine Lwb also was told needs
new heating plugs anyone know cost to replace.
thanks
Julia
staites
Re: high pitched noise under bonnet
Postby DEAN MACHINE » Thu Jan 28, 2010 4:42 pm
staites wrote:Hi everyone, i have looked at van today first one, never bought one before, the van has a high pitched sqeeling sound
thanks
Julia
hi there , sounds like belt squeeling , tensioner pulley bearing :idea: , why does it need glow plugs? , the 2.4 engine will start ok without them
DEAN MACHINE
Postby staites » Thu Jan 28, 2010 5:02 pm
They said when gets cold takes a while to start but will start eventually that's why they said heating plugs need changing,
as for belt noise doesn't sound like that he did say that it was coming from the alternator but he said it was charging
fine with no problems.Thanks for your comment and help
staites
Postby bazw » Thu Jan 28, 2010 5:20 pm
sounds like the bearings in the alt are done for if thats where the noise is from
have a search in the forums for "glow plugs" there are a few faults that show up , one is the feed wire from the battery burning out due to a short through a faulty glow plug
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby DEAN MACHINE » Thu Jan 28, 2010 6:59 pm
staites wrote:They said when gets cold takes a while to start but will start eventually that's why they said heating plugs need changing,
with the weather as it is now above freezing the van should start first turn of key without glow plugs , the problem with new glow plugs is not the price its getting the old ones out , they have a habbit of snapping off in the head , as for the noise, take the belt off and start the van if the noise is still there that rules out all the pulleys on the front including alternator
DEAN MACHINE
