Cylinder block drain plug
Postby mike206sp » Thu Jan 28, 2010 5:28 pm
Where is it and what does it look like???
Iv'e been having a root around under the bonnet as I intend to carry out a mini service tomorow before I start the 9 hour drive to Kent on sunday and noticed the coolant looks a funny shade of brown. So flushing out the coolant system is on the cards aswell and replacing it with the proper pink stuff.
I cant seem to find the cylinder block drain plug though. HELP!
Shes a mk5 2.5 non turbo.
cheers
Mike
mike206sp
Re: Cylinder block drain plug
Postby lewisdale » Thu Jan 28, 2010 5:59 pm
just undo the bottom hose off the rad to drain it
lewisdale
Postby bazw » Thu Jan 28, 2010 6:14 pm
or look under the bottom hose on the rad mine has a drain cock there :wink:
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby mike206sp » Thu Jan 28, 2010 7:14 pm
Will that drain the whole system??? Is it best to flush it though with just a hose or should I use an additive aswell???
mike206sp
Postby barabas » Thu Jan 28, 2010 7:53 pm
iirc, its a wee hex(?) plug on the block under/forward of the exhaust manifold, doesn't look like much..
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby mike206sp » Sat Jan 30, 2010 5:07 pm
OK,I drained the system,filled it up nice and slowly with some rad flush,ran it around 20 miles,drained the system again and when I started to flush it through water started p**sing out from around the water pump area and dripping off the sump. I managed to get it filled with coolant and tried running it. The pump is circulating the coolant and everything is getting warm but it does sound a tad noisier than norm.
Is it a seal or something round the pump thats the problem??? or is the pump on its way out???
mike206sp
Postby Guy88 » Sat Jan 30, 2010 5:10 pm
sounds like you water pump needs replacing along with gasket,
coolant will degrade the timing belt too :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Sat Jan 30, 2010 5:11 pm
Bearings on water pump are shot.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
