1998 2.5 promlems after vandalism
Postby bookmark » Fri Jan 29, 2010 9:43 pm
a wrecked steering column and broken window,window replaced BUT the replacement column is causing problems,wont start either with the key supplied or the original. tried all sorts of permutations but none work ,six hours in the freezing cold aint no joke. any ideas on how to start or how to bypass the pats security, wired direct it will turn over but wont fire,any suggestions before i weigh it in :twisted:
bookmark
Re: 1998 2.5 promlems after vandalism
Postby GBBiker » Fri Jan 29, 2010 9:49 pm
Oooooh, first post and asking how to bypass the immobiliser :!:
Suspicious? You bet :evil:
GBBiker
Wrong Again!
Postby ake » Fri Jan 29, 2010 10:02 pm
It always makes you wonder doesn't it when someones first post is to ask how to bypass the immobiliser. :? :? :? :?
It sounds to me like you need to replace the sensor ring round the barrel which reads the code from the key, also check the fuses for the immobiliser
Postby bookmark » Fri Jan 29, 2010 10:31 pm
suspicious maybe but i'm an oap and the transit is my daily driver,i can't afford main agents prices and at the moment the van is worth scrap price like any 12 year old van and the ring has been replaced,and by the way all this is because of some mentally retarded toe rag who thought that he could bypass the immobiliser has left me without transport .if i'd have known that other posters would be suspicious and question my motives i'd have left the grips on whats left of the steering lock and left the key taped to the circuit board , at least it was driveable that way. all i want is to be able to drive my prefered mode of transport looking the way it did before my night visitor and get it driveable for as little money as possible,it's already cost a weeks pension in bits, bill ,bookmark.
bookmark
Postby AndyG » Fri Jan 29, 2010 10:35 pm
Perhaps one of us could pop out and help you :?:
Where abouts are you bookmark :?:
Postby trigger » Fri Jan 29, 2010 10:44 pm
Andyg wrote:Perhaps one of us could pop out and help you :?:
Caravan site probably :lol:
Mk5 Transit the daddy
trigger
Postby AndyG » Fri Jan 29, 2010 10:51 pm
Imageand so :?:
Postby trigger » Fri Jan 29, 2010 11:06 pm
Imageand so :?:
Think about it, first post and he wants to bypass the immobiliser or he's gonna weigh it in :wink:
trigger
Postby bookmark » Fri Jan 29, 2010 11:09 pm
ah! members with a sense of humour, i live in stoke -on-trent st11 postcode, i don't mind telling you that because if you se the van you wont be able to nick it, 'cos it wont bloody start, (unless you own a hi- ab of course),i'm beginning to feel at home already.
bookmark
Postby AndyG » Fri Jan 29, 2010 11:15 pm
Now that's a little further than I'd like :|
Postby trigger » Fri Jan 29, 2010 11:17 pm
Sorry mate, it's just it looks suspicious when someone signs up and the first post is how to disable the immobiliser, my apologies to you
trigger
Postby darkbluevanman » Fri Jan 29, 2010 11:18 pm
Imageand so :?:
Take the tools outta the van before you go?
darkbluevanman
Postby madbri » Fri Jan 29, 2010 11:19 pm
trigger wrote:Sorry mate, it's just it looks suspicious when someone signs up and the first post is how to disable the immobiliser, my apologies to you
i was thinking the same :wink:
madbri
Postby darkbluevanman » Fri Jan 29, 2010 11:20 pm
bookmark wrote:ah! members with a sense of humour, i live in stoke -on-trent st11 postcode, i don't mind telling you that because if you se the van you wont be able to nick it, 'cos it wont bloody start, (unless you own a hi- ab of course),i'm beginning to feel at home already.
I'm an african Prince, I have inherited £15 million English pounds, would you help me transfer it to a UK bank account, please send me your Bank details, full address and phone numbers, for you kind help I will give you £1 million English pounds :wink:
darkbluevanman
Re: 1998 2.5 problems after vandalism
Postby AlanN » Fri Jan 29, 2010 11:54 pm
No one will tell you how to by-pass your PATS on-line, just not the done thing, but people will help you get around the problem you have :D
Good luck
