water in drivers side footwell
Postby lwbht » Sun May 21, 2006 6:56 pm
Hi new to the forum as have only just purchased a long wheel base hi top 100 transit year 2000 smily face. when I picked it up last week the rubber matting was wet underneath and it has stood in my driveway for the last 2 days in the pouring rain. Went out to it a few minutes ago and discovered the matting is wet on the drivers side with a puddle up one corner. Have had a look around but can't find where this has been coming in . I noticed an earlier thread that some transits have a leak underneath the battery tray. Before I disconect this to have a look can anyone tell me if this will upset anything apart from the clock and the radio code. Or does anyone have any other ideas where to look for the leak. Many thanks.
lwbht
Postby Luke » Sun May 21, 2006 7:00 pm
thats a coincedence just been talking about this, the post under yours :shock:
http://fordtransit.org/forum/viewtopic.php?t=6021
have a read through that :D
Postby lwbht » Sun May 21, 2006 9:07 pm
Luke wrote:thats a coincedence just been talking about this, the post under yours :shock:
have looked at that post but water is not coming from the a frame. do you know the answer to the battery query?
lwbht
Postby Luke » Sun May 21, 2006 9:13 pm
dunno how the battery tray can cause a leak - its on the front part of the inner wing innit?? :?
Postby madvanman » Sun May 21, 2006 9:33 pm
my hicube had a similar problem but both sides were getting wet, it was a leak around the windscreen on mine (water was travelling along the dash support bar and dripping by the pedals on the drvers side and running down the passenger side bulkhead)
first try taking off the drivers side A pillar trim and looking at the bottom of the windscreen when its raining to see if there is any signs of damp (its a bit easieyer than removing the battery)
madvanman
Customised!!
Postby Guy88 » Sun May 21, 2006 10:24 pm
My Mk3 is the same. the passenger side foot well is wet :(
I was thinking the battery tray but im not sure now :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby trannyvan » Sun May 28, 2006 10:12 pm
hi guys i had the same in my mk 5 after taking the front seats out and floor matt, i had my bro spray a hose pipe in the arches and we found that they had not seam sealed the top strut where the shock goes, the wheel was flicking water up and it would get wet under the matt. i bought some seam aesler and pumped it in there let dry and put it back together, then undersealed the under the arches, that was 4 years ago and its been dry ever since. hope this could help you.
trannyvan
Postby maxlee » Mon May 29, 2006 8:34 am
Guy88 wrote:My Mk3 is the same. the passenger side foot well is wet :(
has it got Aerial on the passenger side? these can leak and run down to the step on ontop of the step making it rot
maxlee
Postby crazyscoot » Mon May 29, 2006 8:46 am
mine leaks and its the windscreen thats causing it. Unfortunatly its a screen out job which i will get around to doing sometime......err .....soon :roll:
Negative reality inversion
crazyscoot
Postby Guy88 » Mon May 29, 2006 9:39 am
Nope no areal and just had new screen :?
It seems to be coming in behind the heater and running down the pipes to the vents :? it seems to do it when i drive thru puddles :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
