Key fob - reprogramming spare?
Postby berbeck » Tue Feb 09, 2010 11:38 am
Hi guys,
My key fob is getting harder and harder to use.
I have opened up the back and it appears the three little nipples are virtually compressed flat. They dont spring back up.
I have a brand new spare fob from my other Transit - can I reprogramme this one to use on my other van?
....or am I going to have to go to Ford and get stichced up for £50 :(
berbeck
Re: Key fob - reprogramming spare?
Postby GBBiker » Tue Feb 09, 2010 11:40 am
Can't you just swap the circuit boards over? I mean, put the original one into the new case?
GBBiker
Wrong Again!
Postby captain hook » Tue Feb 09, 2010 2:00 pm
Yes, very easy 8) If you do a search you will find it's been covered a few times on here.....
captain hook
Postby berbeck » Tue Feb 09, 2010 2:36 pm
GBBiker wrote:Can't you just swap the circuit boards over? I mean, put the original one into the new case?
Yeah, thats what I thought.
Its hard to describe...I'll post a couple of pics when I get. It'll prbably make a bit more sense.
berbeck
Postby berbeck » Tue Feb 09, 2010 3:28 pm
OK, heres the pictures -
We have two transits. Both the same year and model.
They keyfob on the left is from Transit 1, they key on the right is from Transit 2
Transit 1 is used by two drivers (myself and another guy) so we need both keys and fobs.
Transit 2 is only used by by my son. Hence his spare is perfect and has never been used.
I cant just swap the circuit board as this wont operate Transit 1. I thought maybe it was just the rubber case that was wearing thin, but it isnt. Its the three little nipples that have been compressed by constant use.
When I press the nipples on my sons spare you can hear it click. When I press the nipples on my spare you cant hear anything.
This my circuit board - discoloured nipples and flat
This is my sons spare keyfob - lovely and clean
The rubber housing is fine. I've tried swapping them over.
Is there some way I can re-code the circuitboard for my sons van spare keyfob to make it activate my doors?
berbeck
Postby captain hook » Tue Feb 09, 2010 3:43 pm
captain hook wrote:Yes, very easy 8) If you do a search you will find it's been covered a few times on here.....
captain hook
Postby ake » Tue Feb 09, 2010 9:33 pm
Ignition on and off 8 times leave on on eighth go, locks cycle, press one button on each fob, locks cycle each fob, turn off ignition job done
