100ps_drw_hicube wrote:not to hard to do your self i done my last one didnt take that long tho my dad had his last one fitted cost around£160 ish i thinkcant remember exactly
100ps_drw_hicube wrote:1 question why a spanner on the propshaft why not a socket or even better a air tooli done the whole lot on my van with a airtool then just torqued it all up after wards
saves yer knuckles too
im sure a certain someone will disagree with this tho
rover wrote:Maybe cos a socket wouldnt fit.... Depends on which prop you have and which bolts, I had to use a 16mm spanner with a thin ring end on my prop, my other 16mm spanner nor any of my sockets would fit (and I have a LOT of sockets),
MarkM wrote:I had a puncture repair done this week and I was very pleasantly surprised to see the guy replace my wheel and use a torque wrench to set the bolts
MarkM wrote:gemini wrote:that must be a first
Well you can guess I didn't go to Kwik Fit
rover wrote:MarkM wrote:gemini wrote:that must be a first
Crickey...did you use 'Angry Al', he's the only guy I know who Tourques up wheel nuts, and subsequently the only guy I ever use for tyres![]()
Rover.
MarkM wrote:but then how do you torque a bolt with only spanner clearance?
100ps_drw_hicube wrote:MarkM wrote:but then how do you torque a bolt with only spanner clearance?
with a torque spanner !!!!i have 2 of em both are 15mm not much use to me
we got them free with machines we have bought in the past
