MrMPuk wrote:Try a proper motor factors, Halfords are pants.
merv wrote:MrMPuk wrote:Try a proper motor factors, Halfords are pants.
well in one way I agree, but years ago they helped me out of a tight spot over one easter bank holiday weekend and without em I'd have been stuck 300 miles from home, so at times they have come in handy..
So not a ford only part then? I thought that a bit strange when that spotty faced sod in halfords told me that today, still pissed off with fords quote though, I know ya pay more for genuine parts, but 46 quid was over double what I expected even from fords.
winterheating wrote:
they sould only be about £12 from ford though![]()
unless, they may give you the whole housing part with the 2.4 i think.
why do you suspect the main stat![]()
the oil cooler stat is far more common.
winterheating wrote:start the van from cold, with no blowers on, let it run 5 minutes, then check the 2 pipes to oil cooler, get too them from bottom of engine on passenger side, they should both be cold if oil cooler stat is not passing.
check top rad hose should be cold also if main stat is not passing.
check the 2 pipes going to heater matrix, both should be almost the same temp, if not then water pump could be failing, which would then cause the main stat to open prematurly anyway.
winterheating wrote:yeah defo sounds like the oil cooler stat, if it were working ok the temp should never drop below 76degrees.
what you got 125ps fwd or 135ps rwd tdci
I did question if it was just the stat or the whole housing and the fella at at the ford MD said it was for the stat only, even HE thought it was a bit expensive.
The reason I thought it was the water stat is because it seems to take a hell of a long time to get up to normal running temp, about 15 to 20 miles of normal driving miles, then if I put the heating and blower on the temp drops on the gauge just drops real rapid, all this with No water loss. Maybe it IS the oil cooler stat, what do you reckon going by those symptoms?.
BTW, I really do appreciate the advice you guys give out.... its far better than I got from Fords & HalFORDS![]()
