Does anyone know if it's possible to tap into the rear indicators and/or hazard warning light switch so that the strobe lights only come on when all the indicators are flashing?
TIA
trigger wrote:I would think you would have to run a wire and tap into the hazard relay as you cannot tap into the lights themselves as they would flash with the indicators
ireland.1495 wrote:easier just to use a seperate switch & flash relay
