cooling prob
cooling prob
Postby paul carps » Sun Feb 28, 2010 12:16 am
hi can anyone help me whilst driving today i noticed my temp gauge was reading zero. i checked my water level which was ok. as i was driving my light for the glow plugs was flashing on and off and i lost power, so i pulled into a layby and turned my engine off. i restarted it after about ten mins and the temp gauge went to norm position but as i carried on driving the temp gauge went back to zero. any ideas what the prob could be.
cheers paul
paul carps
Re: cooling prob
Postby KH_Towbars » Sun Feb 28, 2010 12:58 am
most likely the coolant temperature sensor located in cylinder head (behind pulley on right hand side of engine) try unplugging to se if there is any difference but you will still get glow plug light flashing and low power as it is in limp mode
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Re: cooling prob
Postby paul carps » Sun Feb 28, 2010 7:11 pm
thanks for that the heating coil light only flashed until i stoped the engine it hasnt come on since but the temp gauge is still at zero, i will get it to my local garage tomorrow.
paul carps
Re: cooling prob
Postby ake » Sun Feb 28, 2010 7:45 pm
Could also be knackered water pump
Re: cooling prob
Postby RFC417 » Mon Apr 19, 2010 1:47 pm
paul carps wrote:hi can anyone help me whilst driving today i noticed my temp gauge was reading zero. i checked my water level which was ok. as i was driving my light for the glow plugs was flashing on and off and i lost power, so i pulled into a layby and turned my engine off. i restarted it after about ten mins and the temp gauge went to norm position but as i carried on driving the temp gauge went back to zero. any ideas what the prob could be.
cheers paul
paul carps wrote:thanks for that the heating coil light only flashed until i stoped the engine it hasnt come on since but the temp gauge is still at zero, i will get it to my local garage tomorrow.
I have a similar problem with my 02 plate 2.5d transit. No problems with temperature gauge, water level etc but a few times in the last couple of months I have lost a bit of power, maybe 15%, and the heating coil warning light has came on flashing.
Pulling in and switching off the engine for a few minutes does the trick and everything goes well again. Due a service and mot in a month but wondered if anyone has experienced the same or can shed some light on the problem.
Don't want to run it and do damage but because it seems ok I was going to chance it for the month. Usually do 100 - 200 mile runs and was waiting for the holidays and annual service.
RFC417
Users browsing this forum: knobby1
