Small electrical problem
Postby trigger » Tue Mar 02, 2010 9:50 pm
After fitting the Tourneo roof lining with all those extra lights i could smell like burning plastic near the fusebox, i felt all the relays and one was hot so i pulled it out, the interior lights now don't come on when the drivers door is opened but do when the others are, it's a White relay with a printed circuit inside and only has 3 pins, i have discovered it's the lights on buzzer, do you think the extra lights in the back are causing it to burn out?
White relay (buzzer)
Burnt corner of circuit board
Mk5 Transit the daddy
trigger
Re: Small electrical problem
Postby KH_Towbars » Tue Mar 02, 2010 10:08 pm
I would say so, maybe the tourneo relay is different, any chance of getting hold of it or maybe someone with a tourneo will have a look for you and match part no. on relay :?:
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Postby KH_Towbars » Tue Mar 02, 2010 10:13 pm
the bit thats burnt out on the relay could be an in-line fuse, cant see very good in the pic of the circuit board, does it look like the track has burnt or a component blown/popped :?:
SOLD VW T5 102 SWB
KH_Towbars
Postby trigger » Tue Mar 02, 2010 10:20 pm
It looks like a small component or chip, it's a small Black rectangle bit that is soldered on each end, it's got a number on it 5m 87, it smelled like burning plastic and it still does smell burnt
trigger
Postby ake » Tue Mar 02, 2010 10:27 pm
Are you sure you dont have a trapped or crossed cable somewhere on the new lights :?:
Postby trigger » Tue Mar 02, 2010 10:33 pm
Don't think so, surely the fuse would have gone bang if there was a short?
trigger
Postby KH_Towbars » Tue Mar 02, 2010 10:35 pm
also did it burn out whilst you had the drivers door open :?:
SOLD VW T5 102 SWB
KH_Towbars
Postby trigger » Tue Mar 02, 2010 10:43 pm
KH_Towbars wrote:also did it burn out whilst you had the drivers door open :?:
Yes, i was hoovering out the drivers side of the cab area when i smelt it
trigger
Postby ThommoHawk » Wed Mar 03, 2010 12:02 am
Looks like it might be a small inductor (coil) for noise suppression. These are normally sized to suit the current/load passing through them so I guess it's possible that adding the increased load of additional lamps may well have caused it to heat up.
Just as well you smelt it really...
regards
Paul
(aka ThommoHawk)
Too many hobbies :-) ----- too little time :-(
ThommoHawk
Postby KH_Towbars » Wed Mar 03, 2010 12:14 am
When you open the door the door pin switch puts an earth to the interior lights as they are earth switched, all I can think of is the earth is bad i.e. the pin switch may need replacing when you replace the relay that is if the tourneo relay is the same as yours.
hope this helps
SOLD VW T5 102 SWB
KH_Towbars
