power loss after service
Postby david p » Thu Mar 04, 2010 10:11 pm
hi
after servicing my tranist I now have severe power loss . places usualy done in 5th gear now needing 4th or even 3rd
2001 transit diesel
75 ps
changed oil fuel and air filters
and oil
no sevice for around 50 000 miles before this
the air filter was in extremely bad shape soggy and congeled
until service she was going like a dream
thanks for any help
david p
Re: power loss after service
Postby Vee4 » Fri Mar 05, 2010 9:38 am
david p wrote:changed oil fuel and air filters
Is it a late Mk5 or a Mk6? My guess would be air ingress after changing the fuel filter. Course of action depends on your model. Try a search such as:
search.php?st=0&sk=t&sd=d&keywords=di+fuel+filter&fid%5B%5D=4
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Postby 75psT330lwb » Fri Mar 05, 2010 9:45 am
filter might not be fitted properly and drawing air in through seals. take filter off and make sure its full then refit nice and tight and twist locking ring, this shouldnt have any resistance hardly when locking it in. if it does it means the filter isnt pushed fully home. or pipes may have been knocked and arent seated correctly, try pushing all connectors onto filter head to make sure there sealed.
Custom Ecoblue
75psT330lwb
Postby david p » Fri Mar 05, 2010 7:37 pm
many thanks
filter was only 2/3 full so i think its prolly a diesel issue
havn't tried out yet but will shortly
thanks again
david
david p
Postby david p » Wed Mar 10, 2010 8:46 am
hi jus to let u know
tried a new genuine diesel filter no change
then took filter of again to try and blow back intake line with air line
discovered rubber fitting from first filter had stayed on the drop pipe from filter head
removed problem solved
david p
Postby david p » Sun Mar 14, 2010 3:57 pm
david p wrote:hi jus to let u know
Problem not solved
back to square one
have since changed filter head and checked fittings but still low on power
no smoke
filter always half empty when i check
no probs starting
If she is drawing air between filter and tank why is she just not drawing only air ?
any help much appreciated
david p
