which transits have glow plugs?
Postby gdoldtransit » Thu Mar 11, 2010 10:13 am
hi
im looking for a newer transit and i quite like the look of the mk6 transit...
do they have glow plugs the mk6's as i need one with glow plugs as do not want anymore cold start probs??
thanks
sam
gdoldtransit
Re: which transits have glow plugs?
Postby jonb1 » Thu Mar 11, 2010 10:21 am
all the mk 6 tranys have glow plugs , manly for emission control but they start well in cold
jonb1
Postby jay » Thu Mar 11, 2010 6:04 pm
depends where you live as a Di transit will start in freezing conditions..A lot of cold start problems are from duff batterys and bad connections or dieing starter motors...I have not had a bad starting Di even one that used a lot of oil and smoked a lot still started up ok.....mk6 and mk7 have glow plugs but mainly for emmisions on cold starts as they will start no problem without them connected up..
mk1 connect tourneo
jay
Postby psv-hgv-flt » Thu Mar 11, 2010 11:04 pm
if it is the 2.0 that you are going for then get the 125 bhp tdci they start the best. (i pulled the relay out 3yrs ago) and not even this winters -o temp made any diffrence. :D
psv-hgv-flt
Postby Panage » Fri Mar 12, 2010 12:47 am
Mines a 2litre 2002 85ps with a 120000 on and up until recently the glow plugs wernt even connected and it started first click of the key even in the snow and ice, to top it all off the battery is well past it's prime.
Ive re-connected 2 of them now and its just made it a bit smoother when i first pulled off in the morning, otherwise no difference, the other 2 are just bolts after the plugs snapped. so i dont realy understand the point of them if they dont seem make any odds :?
Any one know what they do emmision wise?
2002 Ford transit swb 2.0 85 T280.
Panage
Postby jay » Fri Mar 12, 2010 8:34 am
they help stop the puff of black smoke in the morning and reduce i think its NOX levels on start up.
mk1 connect tourneo
jay
Postby Panage » Fri Mar 12, 2010 10:16 am
That'll be why theres a black patch forming on the drive behind the van then. :roll:
Is it likely to fail an MOT with those raised levels?
Panage
Postby psv-hgv-flt » Fri Mar 12, 2010 10:58 am
jay wrote:they help stop the puff of black smoke in the morning and reduce i think its NOX levels on start up.
no diffrence on mine.
psv-hgv-flt
Postby bazw » Fri Mar 12, 2010 1:39 pm
Panage wrote:That'll be why theres a black patch forming on the drive behind the van then. :roll:
will be warm when you go for test as you have to drive it there so will not effect it i would have thought
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby jay » Fri Mar 12, 2010 10:22 pm
no makes no diffrence to mot as the engine will be tested when hot and not from a cold start up..
mk1 connect tourneo
jay
Postby winterheating » Fri Mar 12, 2010 10:28 pm
gdoldtransit wrote:hi
thanks
sam
have a quick look here aswell
viewtopic.php?f=5&t=57908&start=0&hilit=cold+starting
winterheating
