horn not working
horn not working
Postby hammer » Fri Mar 12, 2010 4:45 pm
hi horn not working on my 2001 transit tested wire at s/sheel with test lamp there is power but it very week it just about lights up test lamp dose it run with a relay if so wher can i find it thanks hammer
hammer
Re: horn not working
Postby bazw » Fri Mar 12, 2010 6:39 pm
iirc horn push on steering wheel on most cars is an earth not a feed so will show low power if horn dead , you need to test the wires at the horn and see if one is live all the time , other will be an earth when horn push is pressed and no circuit when not
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby ake » Fri Mar 12, 2010 7:18 pm
horn ray in engine bay fusebox, get someone to push horn button while you listen for relay clicking, usually horn itself that fails
