by MK7TDCI08 » Sun Mar 14, 2010 9:16 pm
The mk7 is self bleeding but you must make sure you fill the filter completely, shakeing it when you fill it to expel any trapped air then top it off and carefully replace it , start the engine and run it for a minuet above idle, job done.The air is probably getting in from one of the fuel line connections, maybe a faulty O ring. I have air in my fuel line but it goes away when I take the van for a blast down the road then slow town driving it comes back so i am replacing all fuel lines and fitting good old hose clips.
If tradesmen are meant to be experts,why do they get sent back with a snagging list.
