4.2t dw dow rated to 3.5t
Postby ryanpropertyservices » Mon Mar 29, 2010 10:11 pm
Anyone know how this is donne and where
also how about london LEZ charge gettig particle filter fitted
Re: 4.2t dw dow rated to 3.5t
Postby AndyG » Mon Mar 29, 2010 10:15 pm
Postby ME » Mon Mar 29, 2010 10:27 pm
ryanpropertyservices wrote:Anyone know how this is donne and where
Down rating is a paper work exercise at the local Vosa/DOT Mot testing station
Mercedes Vimto Premium
ME
Postby jay » Tue Mar 30, 2010 7:59 am
need to know what engine you got fitted first..if a old 2.5 Di then you cant unless you spend a lot of money..2.0 or 2.4 depends on the year atm.
mk1 connect tourneo
jay
Postby ryanpropertyservices » Tue Mar 30, 2010 3:01 pm
its 2.5 125bhp dbw rated to 4.2 eed 3.5 to hopefully pass LEZ
anyone got details of vosa that coverns west london
Postby AndyG » Tue Mar 30, 2010 6:54 pm
What's your registration and or chassis number :?:
Postby MinorMatt » Tue Mar 30, 2010 6:56 pm
so its a mk6/7? In which case its LEZ compliant anyhow
Postby ryanpropertyservices » Tue Mar 30, 2010 7:34 pm
REG IS EO52CZG
I HAVE CHECKED THE LEZ SITE AND IN 2012 IT WILL COST 100 DAY TO USE IN LONDON
I THIK ITS THE WEIGHT 4.2T SO THIS IS WHY I NEED TO GET IT DOWN TO 3.5T
Postby AndyG » Tue Mar 30, 2010 7:55 pm
2.4 litre :!: :wink:
And yes, you are correct, over 3.5 tonnes and you'll need to be Euro IV for PARTICULATES :!:
But Ford in their wisdom will sit there banging their Euro 3 drum (as they ignore the fact that you are probably Euro IV for particulates anyway :roll: )
But don't panic, we have a bit of time before Jan 2012 :!: It can still change before then :wink:
Postby ryanpropertyservices » Tue Mar 30, 2010 7:59 pm
how do i go about bringing weight down
Postby AndyG » Tue Mar 30, 2010 8:20 pm
You can :!:
I'm trying the search for you now :!:
There is a place that can down rate your Transit :wink:
Postby AndyG » Tue Mar 30, 2010 9:04 pm
Postby Frag » Tue Mar 30, 2010 9:36 pm
Change front struts & springs,door badges & weights sticker......
Rest is paperwork i.i.r.c :?
Frag
Ford Technician
Postby Luke » Tue Mar 30, 2010 10:03 pm
Frag wrote:Change front struts & springs,door badges & weights sticker......
is that for uprating :?: and is it the same for up and down ie does it need the correct rating bits :?: just we were thinkning of downrating the cossy mk6 from a T330 - adding side windows and making it a car classification but for it to be classed as a car it needs to be lot lower gvw than 3300 :)
Postby sc_BK » Wed Mar 31, 2010 1:24 am
Luke wrote: just we were thinkning of downrating the cossy mk6 from a T330 - adding side windows and making it a car classification but for it to be classed as a car it needs to be lot lower gvw than 3300 :)
What about fitting windows both sides, rear windows, and a row of rear seats, then it is classed as a dual purpose vehicle?
sc_BK
