big mk5 wrote:hi i think your better using grease or oil rather than wd40...wd40 works short term but is only for water dispersant rather than lubrication....ive not got the same transit as you but id say that maybe the door or lock has dropped so id see if there is any way you can adjust it ...hope this is helpfull
adaturfman wrote:Going to try spraying in the lock and see what happens. If no luck I'll strip down the door and explore!
adaturfman wrote:In the meantime would this van originally have come with a remote and if so how easy would it be to buy one and program it to the van. At the moment I only have keys for opening the door's.
adaturfman wrote:Silly question I know but is there any way this can go tits up!
