Mk 4 2.5 N/A Engine with Lucas pump. got problems with engine as seen in my other post so want to convert to bosch pump. Have changed the pump but not to sure I have it right so is there a step by step guide to the process. IE what do I need parts wise and setting up etc. Just need to eliminate this from the problem. Do I need to change injector pipes etc. Injectors are the white spot pencil type.
Graham
