Building a false floor
Postby mapleford » Fri Apr 02, 2010 1:08 am
Hi all,
I'm looking to build a false floor in my mk6 so I can slide 8x4 sheets in when needed but keep all my tools above. Any ideas what thickness ply I should use, I weigh in at about 18st and I don't really want to fall through or have it bow over time.
Cheers :mrgreen:
mapleford
Re: Building a false floor
Postby Backbone of Britain » Fri Apr 02, 2010 1:19 am
you would be better off building a rack to slide the sheets in upright. Even 3/4" ply will eventually bend with quite a bit of weight on it if only supported at the sides.
Last edited by Backbone of Britain on Fri Apr 02, 2010 1:20 am, edited 1 time in total.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby ZeldaTheWelder » Fri Apr 02, 2010 1:19 am
mapleford wrote:Hi all,
Cheers :mrgreen:
I did that in my van severall years ago but recently took it out again as change in use.
I used stud work timber as was cheap and you dont get splinters as easy.
i put a lenght down each side screwed into the side then fitted cross bars and then used 3
of the big loft boards cut to size. was really strong and didnt weigh to much.
96 mk 4 smiley banana swb semi hi top
Mk6 swb low top with even more rust!
04 Connect T220 LWB.
ZeldaTheWelder
Postby jolly olly » Fri Apr 02, 2010 11:39 am
Here is what i knocked up to carry sheet materials, this way you can have various size sheets so you can just slide them out as and when.
Its a bit rough but has served its purpose very well, it will be removed soon as its no longer required.
Life is not a dress rehearsal
jolly olly
Postby earthman » Sat Apr 03, 2010 9:00 pm
Cheers :mrgreen:
How about making 3 beams out of box section steel that would help support the false floor?
earthman
