cooling problem
cooling problem
Postby deepak » Sun Apr 04, 2010 11:19 pm
my 2006 2.0duratorque transit tourneo,cut out.temp gauge rose,fan cut in,hose pipes cool,heater blowing out cold air.
deepak
Re: cooling problem
Postby winterheating » Mon Apr 05, 2010 1:38 am
is the water level ok :?:
if it is, then water pump may have gone, or more likely the splines from pas pump to water pump will have stripped.
winterheating
Re: cooling problem
Postby deepak » Mon Apr 05, 2010 4:50 pm
water level ok.any more info welcomed. thanks winter heating
deepak
