Hi, just wondered if someone could advise me on how to wire in a twin light bar on my Connect!? The way I was thinking of doing it was -
1, find a permanant live behind the dash & cut into it (colour, position??)
2, run a short wire to one terminal on the switch (with a in line fuse)
3, from the other terminal on the switch run a wire to the beacon +
4, then run a wire from the beacon - to a clean bit of body!!
Is this the right way or the stupid way to do this little job & if it is the right way could I do my rear work lights like this to!?
Did do a search but couldn't find much so could you help??
Dodge
Blanked EGR, K & N Air Filter.
