I posted this last week but didn't have much response as I don't think the fault was well described. After a trip to Portsmouth & back I am better acquainted with the sound! It relates to a 1999 Ford Transit 190 with a 2.4 diesel engine (non-turbo).
Under acceleration in all 5 gears there is a screeching noise coming from the LHS of the engine (almost as if it's coming from the glove box). It sounds like a loose fan-belt but only happens when the car is in gear, and accelerating. It also worsens briefly when I take my foot off the gas if the revs stay high and I don't change up. I assume it is not a fan belt as the noise ONLY happens in gear/accelerating, not when I first start the engine from cold. It did not improve over the 100 mile journey over the weekend.
I have read in different forums that it could be the cam belt or auxiliary drive belt. Any opinions here? Are either of these things I could replace with limited knowledge, a decent tool kit and a Haynes manual!?
