2001 transit steering
Postby ALZI1967 » Wed Apr 07, 2010 1:40 pm
Hi ,
My van is a 2001 mk6 transit 350 lwb - rear wheel drive with the 2.4 duratorq engine
Ive been having a few issues with the steering on my 2001 transit for the past 2 weeks
Some days the steering is nice and light , can turn the steering wheel with say 1 finger.
sometime later it will require a heavy pull on the wheel to turn it.
next day it may start off heavy then after 10mins will go light.
I thought i'd solved it with a fluid change as the old stuff was brown and yuk , but no particles of metal in it - just burnt looking.
so anyway changed fluid - it seemed to work fine the rest of the day . then next day intermittent light then heavy.- it doesnt matter what the engine revs are and its got a a new serentine(fan) belt on ,there are no fluid leaks anywhere on the steering rack or pipes..
After a couple of days of still intermittent heavey/light steering , I decided to stretch the pressure releif spring inside the pump apparently this should increase the delivery pressure. and for that day and the next . the steering went nice and light , just how it used to be.
Alas it didnt last..
its recently had its MOT , no play in bottom ball joints - only failed on o/s track rod end - replaced with genuine ford item.
im leaning towards the pump ,but Any Ideas ???? please help ...
ALZI1967
