shifting down the gears,
Postby fatboy45 » Fri Apr 09, 2010 7:39 pm
my smiley fronted 2000 w,reg diesel transit is playing up again, i havent had a transit for a few years so cant remember all the things that go wrong with them, here we go' when im driving and slowing down and and going down through the gears i can get it in to a lower gear, with out a crunch, im not usre if the clutch is on its last legs, the pedal bites quite near the floor, and dosent slip. can some one advise if its the clutch, i remember vaugley 10 years ago i had something like this but it was to do with a bit on the clutch pedal, any help would be appreciated, rgds mike
fatboy45
Re: shifting down the gears,
Postby minimadmatt1975 » Sat Apr 10, 2010 10:49 pm
Your thinking of the ratchet auto adjuster. Try resetting it (i think you just pivot it back but not sure) although they do wear out. Had to do one on an escort years ago which was fiddly but more space to work in the tranny. If not the cable adjustment could be syncros in the box.
1999 MK5 120 SWB 2.5Di 70ps
minimadmatt1975
Postby flyingclutchman » Wed Apr 14, 2010 7:38 pm
No auto adjuster on this model, 10mm nut on end of clutch cable. Try tightening it a few turns. If you need to keep tightening it regularly it's probably the clutch arm cracking slowly.
flyingclutchman
Postby fatboy45 » Sat Apr 17, 2010 9:47 pm
sorted it was the ratchet on the lever, mike
fatboy45
Postby jay » Sat Apr 17, 2010 10:17 pm
are you sure..or was this a garage diagnois..As that year should be manual adjuster..
mk1 connect tourneo
jay
Postby fatboy45 » Mon Apr 19, 2010 9:09 pm
hello, i put in the local garage, thats what they charged me for, ill have a look in the morning, i havent paid them yet, so thats one good thing, ill let you know, rgds mike
fatboy45
Postby minimadmatt1975 » Tue Apr 20, 2010 3:55 pm
I stand corrected just checked my 99 Di and its manual adjuster.
minimadmatt1975
Postby flyingclutchman » Wed Apr 21, 2010 6:14 pm
Yeah, manual adjusters came in about 95-96. Goes with the low-lift clutch. (mind you I've fitted the high-lift clutch to these with no problems!)
flyingclutchman
Postby fatboy45 » Wed Apr 21, 2010 9:37 pm
latest up date, yes its manual all wright, so went to the garage who done it' and asked what the bill was for for the plastic part, let just say with out going in to detail, im not paying, and and the cocky little git who spoke to me is nursing and sore hoota, rgds mike
fatboy45
