Fault Code Reader
Fault Code Reader
Postby skyman191 » Fri Apr 09, 2010 8:40 pm
I would like some advice on fault code readers, we have a 54 plate LDV with a ford engine showing a flashing heater plug light.
The van has sessions of not starting and has logged a fault, to obtain a fault code reader the question is does the ford engine have a socket to plug one into and what type.
skyman191
Re: Fault Code Reader
Postby angeleye » Fri Apr 09, 2010 8:42 pm
transit plug is under steering column
maybe wrong 16 pin obd11 :?:
angeleye
Postby tradeplates » Sun Apr 11, 2010 2:00 am
On the LDV the odb plug is in the small fuse box under the bonnet to the left of the brake servo. If you are using he snap on type scanner you go in as ford transit,
tradeplates
