I have a mk2 Tranny but a mk3 engine in her. Believe to be the first of the Di's? The engine has a self priming hand pump on the filter on the left hand side of the block.
The problem I have is... I bought her as a non runner
Replaced the priming pump but checked it first and it was ok... but replaced it anyways. Took the electric pump off and sorted the rubbers on the injectors. Tried to turn it over but battery was flat, so bought a one for her a heavy duty one and tried to start her. Odd times she start but cut out. So took the rod and spring out of the fuel solenoid. still wouldn't properly. 9 times out of ten she wouldn't run after the key was turned and if she did it was for 3 seconds max. checked if fuel was getting throu and it was? bleed the system, still would not start. Spoke to a lad and he said it was fuel starvation. Checked everything again and even changed injectors. Still nothing.
So.... I put the electronic pump back on (I know they don't need one
But does anyone know why it is that it'll only work with a electric fuel pump cos it's got my had battered
