RADIO DECODED
RADIO DECODED
Postby TRANSBADGER » Sun Apr 18, 2010 4:55 pm
Badger greetings again... :)
My radio code doesn't work...
i turn on the radio it counts down for 30 minutes then asks for code...
when code i have is entered it reverts to 30 minute countdown...
only have 4 more chances according to the manual... :(
any ideas / suggestions / advice to sort this appreciated short of going to the Ford dealer...
many thanks in advance once again... :wink:
TRANSBADGER
Re: RADIO DECODED
Postby ake » Sun Apr 18, 2010 6:38 pm
post the serial no of the unit and we can check you have the right code
Re: RADIO DECODED
Postby TRANSBADGER » Sun Apr 18, 2010 6:49 pm
:oops:
...where do i find the serial no of the unit??
That's probably a really dumb question as i guess it requires romoval of the unit itself...
which leads to the next question of how to remove it as previous experience of radio removal hasnt been good... :roll:
don't want to destroy the thing now do i... :(
TRANSBADGER
Re: RADIO DECODED
Postby madmark_50484 » Sun Apr 18, 2010 7:03 pm
TRANSBADGER wrote::oops:
You need radio keys which you insert into 4 holes at the side squeeze the 2 keys together and pull.
If you don't have keys you can use a metal coat hanger cut it up so you have 2 lots of 2 prongs then follow instructions above.
The serial code should be on a label on it somewhere post the number beginning with M then we will get you the code :D
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Re: RADIO DECODED
Postby TRANSBADGER » Mon Apr 19, 2010 10:47 am
2 bent bits of wire, some wiggling & a small amount of swearing later i have the unit number... :D
M099729
many thanks in advance to the first Tranisteer that cracks the code... :wink:
TRANSBADGER
Re: RADIO DECODED
Postby rob-xcar » Mon Apr 19, 2010 11:31 am
The code that gives me is
6912
rob-xcar
Re: RADIO DECODED
Postby TRANSBADGER » Mon Apr 19, 2010 1:54 pm
:P IT WORKS!!
many thanks rob-xcar... a job at Bletchley Park awaits ya...
:D
TRANSBADGER
Re: RADIO DECODED
Postby rob-xcar » Mon Apr 19, 2010 5:06 pm
No problem , glad to help.
rob-xcar
Users browsing this forum: eddie753
