trigger wrote:It may not be as bad as it sounds, these engines are bulletproof, the screeching when turning the steering wheel deffo sounds like the power steering pump, have you checked the fluid in it? the vacuum pipe leaking is this from the back of the alternator? if it is i had a van with that fault, could be split pipe or seals, have you checked to see where the water could be leaking to? if no visable signs then it could be headgasket
Nadjenka wrote:I'd probably check that the belts are on properly, in line and that they are not overtightened. I'm sure someone will come on with better suggestions, but with minimal knowledge - that's what I would do. The belts shoud easily move when you press your finger on them about 4mm up and down. Or when you should be able to "twist" them about 90 degrees. That soud looks like power steering pump, but again - it could be just very tight beltDid you check your power steering fluid
Also - did you check under your oil cup for any water "foam" - whitish stuff that appears in the tube if water is getting in...?
madmark_50484 wrote:1. Losing coolant sign of headgasket
2. not sure
3. steering thing sounds like power steering pump
p.o.w van wrote:madmark_50484 wrote:1. Losing coolant sign of headgasket
2. not sure
thank, am i correct in thinking that if it was the head gasket there would be a dramatic loss of power ,the leak seems to be coming from the plastic casing that covers the cam belt the water is dripping from just below thecrankshaft pulley do you think it could be the waterpump?
madmark_50484 wrote:p.o.w van wrote:madmark_50484 wrote:1. Losing coolant sign of headgasket
2. not sure
Thats different if you know where its leaking from headgasket won't make much odds to you in the early stages its in the late stages they start giving you problems.
madmark_50484 wrote:you could get a compression test but that could be a red herring I would suggest its not that if you know its leaking I would suggest getting the waterpump done
p.o.w van wrote:madmark_50484 wrote:you could get a compression test but that could be a red herring I would suggest its not that if you know its leaking I would suggest getting the waterpump done
right ok cheers,thats what i was thinking.i had no leaks before the alternater probelm if that garage wasnt 83 miles away id be there now asking i mean telling them to sort it.
madmark_50484 wrote:p.o.w van wrote:madmark_50484 wrote:you could get a compression test but that could be a red herring I would suggest its not that if you know its leaking I would suggest getting the waterpump done
The thing is is it could have got damaged by the belt coming off although the slack power steering belt is definately a bad sign
MinorMatt wrote:A loose power steering belt makes a really horrible grinding noise. It starts on full lock and gets worse as the belt gets looser
