by malbluevanman » Thu Jun 10, 2010 9:24 am
Hi, could be the fuse, but also check the solenoid on the lpg tank - there are 2 connectors there, one is for the sender unit for the fuel guage, the other is for the solenoid that releases lpg. If it's working you will hear a noticable click when it switches over to lpg. Failing that, the only other thing I can think of would be heavily blocked filters. There are 2, one in line and one in the evaporator.
Hope that helps
Mal
