We have an 04 LDV with Ford 2.4TD engine, trying to retrieve fault codes but reader will not find the vehicle.
Any ideas of the protocol and if an OBD11 tester should work ?
angeleye wrote:i believe the only system to work on theses vans is lucas 2000, due to the lucas system dont think there is any way round it,you would also need modual and cable,theres not to many of these 2000s about and hold there value,not sure but think you can change fuel pump( to a bosch) on these and you wouldnt need the lucas 2000 system
you might be able to try a delphi agent they might be able to read codes
ake wrote:Duratorqs before 2005 can be a pest to read with cheaper code readers cos they are not fully obd2 compliant, you may need to try someone elses meter
The Lucas Laser 2000 is for reading MK4 and 5 Epic Turbo Transits
Yeahpsv-hgv-flt wrote:ake wrote:Duratorqs before 2005 can be a pest to read with cheaper code readers cos they are not fully obd2 compliant, you may need to try someone elses meter
and ldv
angeleye wrote:got to changed these frigging glasses 2.4/2.5
