Hi,
I am hoping that someone can help me with a problem. I have a Ford Transit 260 SWB Bi-Fuel 2295CC 03 registration. I have no previous history with this vehicle. The battery light has come on and I think that there is an alternator problem. The casing of the alternator is all cracked. There is a tensioner on an arm next to the alternator, how does this tensioner work to release the belt and re-tension after fitting a new alternator? It's a seven ribbed belt. Also, I have hunted high and low looking for service manual or similar with absolutely no success, has anyone any ideas where i could locate one? There was absolutely no info. with my vehicle, not even a handbook. Also, how do I find the code for the radio as I presume this will be lost if the battery is disconnected? Can you charge the battery in position, connected up as there seems to be a diagram under the bonnet showing leads, is that just for jump starting? It shows a positive next to the fuse box and a negative above and to the left of the engine.
I would be grateful for any help.
Cheers,
Mike
