wandering mk6
wandering mk6
Postby mbev51 » Thu May 06, 2010 7:24 pm
hi
not sure if wandering is the right term. My swb 2002 seems to be a bit loose on the front it wanders a bit, its done about 90k what do you think has worn? Could it be the rear wishbone bushes. Steering joints are ok.
mbev51
Re: wandering mk6
Postby jolly olly » Thu May 06, 2010 7:45 pm
To one side or both?
Life is not a dress rehearsal
jolly olly
Re: wandering mk6
Postby mbev51 » Thu May 06, 2010 9:09 pm
It just seems as if something is worn, not to one side rather than the other. I just doesn't seem to be taught, seems to float around a bit. What normallywears first?
mbev51
Re: wandering mk6
Postby jay » Thu May 06, 2010 9:23 pm
is the tracking ok??
mk1 connect tourneo
jay
Re: wandering mk6
Postby angeleye » Thu May 06, 2010 10:03 pm
are they shocks leaking/check lower wishbone bushes/ tyre pressures/take it for a free check up at a local tyre suspension steering place
angeleye
Re: wandering mk6
Postby mbev51 » Fri May 07, 2010 1:37 pm
hi
thanks for the replies will look into it.
mbev51
Re: wandering mk6
Postby AndyG » Sat May 08, 2010 12:57 am
angeleye wrote:tyre pressures
Probably too high :idea:
Re: wandering mk6
Postby mbev51 » Sun May 09, 2010 7:54 am
hi
not sure what pressures should be as its a lhd german day van conversion made by westfalia. It would have started life as the german equivalent of a torneo. Its a 2.0 tddi (100ps) manufactured 21.08 2001 its gross is 2880. The pressures were around 50-55 when I bought it 4 years ago so I have maintained it around that, I have michelin agilis van tyres on at the moment. It feels like bushes or shockers to me.
mbev51
Re: wandering mk6
Postby AndyG » Sun May 09, 2010 10:44 pm
Check the rack holding bolts and bushes :idea:
Take it for a pre MOT style inspection and tell them to check it out :idea:
Re: wandering mk6
Postby mbev51 » Mon May 10, 2010 7:19 am
hi
thanks for advice. It is due for its 2 year control technique this oct, so will see what they say. They do check each suspension separately so might show up a fault. I have pumped one of my front tyres up from 35 to 55 and things do seem better, it might just have been that.
mbev51
