died whilest traveling
Postby djplastering » Sat May 08, 2010 9:26 am
i have a 2002 2.4 diesel transit when going down the m1 it just died on me as if some one pulled the plug has anyone got any suggestions.i have checked fuel fuses relays all ok.
djplastering
fuel pump
Postby djplastering » Sat May 08, 2010 11:02 am
does anyone know how i can test my fuel pump fuel is comming out as far as the injectors but i dont know if there is enough presure ?
djplastering
Re: died whilest traveling
Postby angeleye » Sat May 08, 2010 5:10 pm
what engine is it ,more details of van the better,any noises when van gave up, any previous work,any lights show up,any other symtoms,etc,who said pump had packed up,could be many things ,but i would start with having the codes read if any,and post them on here to get some sort of diagnosis
angeleye
Postby djplastering » Sat May 08, 2010 6:04 pm
this is all new to me codes i do not understand it is a 2002 2.4 diesel there has not been any problem with the van in the year and a half i have had it,it just stoped as if some one pulled the plug.the rac man said it is probably a fuel pump problem because when he sprayed easy start into it it started, and when he stopped spraying it it stopped.
djplastering
Postby angeleye » Sun May 09, 2010 11:33 am
did rac plug his laptop into the van,the van stores codes into the engine management system,that can be read by the right software,this then can be used to diagnose the problem,it could well be the fuel pump ,but could also be something else ,take it to a garage that can read the codes for you
angeleye
