by angeleye » Tue May 11, 2010 6:12 pm
sounds like you have the dreaded bleed prob,as long as you havnt changed filter to try to get rid of some sort of problem,did you fill filter full of diesel before fitting,when filling with diesel, tap,filter, ,tip slightly, as air will keep coming out of filter,dont just fill it and put back on,air gets trapped in them only fit back on when you are sure its got no air in it,,when it starts crack one injector pipe at a time to try and get rid of any air locks,you may get this right first time if you lucky, but may well have to try 2,3 times,they can be a bit of a b**stard to do,make sure the filter is corectly fitted and tight
